Check out the "Walker" radiator web site. I beleve you will need a shroud to make it work correctly. The "Spal" fan is considered, by most, the best as their test data used a blockage (radiator) in the flow rate data. Others use free air. If your up to it one can build a very good shroud with a piece of aluminum, a brake, and a little tig welding.
