8 members (Bill Hanlon, UtahYork, KEVINSKI, Otto Skorzeny, 37 GC, klhansen, Gazz, Hugh63c10),
124
0
Mod | | | Forums66 Topics128,114 Posts1,056,607 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jake T, if your engine is in good condition and tuned properly it should have no problem supplying sufficient vacuum to power your power brakes. High performance engines with radical cams quite often cannot provide sufficient vacuum at idle to operate the power brakes efficiently, hope that helps.
