My first thing to do would be to drain the oil out of it and see if there is a bunch of metal in the bottom of it. You could pull the side cover and take a look, send pictures when you open it up and someone here will give advice. I may have some parts for you if you need some, I have input, output shafts, cases, complete side cover with shift forks. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
