None that I can think of. As it says in the manual....jack up the front end. Well Duh ! Who wouldn't think of that ? Remove wheel and tire. Remove spindle nut, and pull hub and drum off.
You may have to back down the shoe adj. if the drum wants to hang up on the brake linings as it comes off.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
