| | | Forums66 Topics128,078 Posts1,056,054 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74963 03/19/2007 9:44 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Jerry, You may be trying to accomplish something that is not necessary. What is the position of the arms on the side cover of the transmission? If both are pointed down you could obtain another shift rod similar to the 1-R shift rod for 2-3 and install it in the same manner as on the TF/60's trucks. It will probably take some bending for it to fit. If you have the side cover that has the 1-R shift arm pointing down and the 2-3 arm pointing up, it is probably a car transmission which has a similar set up like your stock AD configuration. If this is the case you could get the truck side cover and install it like I mentioned above. I just did a 6 to V-8 conversion on a 55 and used this procedure. I hope this helps, Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
