3 members (78buckshot, crenwelge, 1 invisible),
79
2
Mod | | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Changing the rear gears should not make the speedo jump around but will change the reading. You will be going faster then it shows. Remove the cable from the speedo head & pull out the core. Feed the core back in with some grease. Put a small amount of oil on the end of the speedo head where the cable goes. Make sure there is plenty of grease in the trans. This should make it work smoother. You may need to get a speedo gear with 1or 2 less teeth. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
