| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | There is no "negative post of the distributor". If the starter is able to turn, the distributor grounds itself through the engine block. No external ground is needed, unless you've got one of those oddball distributors that reverses the polarity on the points every time the starter switch is pushed. Those systems got disabled almost as soon as they were introduced.
Check to be sure you don't have an unintentional ground where the wire from the coil attaches to the distributor. It's a common mistake to allow the stud that goes through the side of the distributor housing to get grounded. This prevents the points from opening and closing the circuit from the coil to ground. If you move the points from open to closed with a screwdriver with the ignition turned on, the coil should generate a high-voltage spark. If the primary circuit is grounded to the distributor housing, opening and closing the points manually won't make a difference. Jerry
