| | | Forums66 Topics128,096 Posts1,056,496 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, you can replace the drums separatly. Just either grind the heads off the rivets and knock them out with a punch, or you can also drill them out. They do not need to be replaced, the hub and drum were originally riveted together to make assembly at the factory faster.
Bill Burmeister | | |
