Healingbear:
Thanks alot for the pics...I was under the truck tonight and the flywheel is pretty dirty..couldn't see anything. Also, I could turn the motor over by hand using the flywheel....the plugs are loose and the dist. isn't in, & no oil in the motor yet. I'll clean the fly wheel up and see what I can see. Now when that is lined up will #1 be TDC ? how will I know if it is commpression or exhaust? Feel for the top of piston ?
Thanks
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
