| | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Can you address the rocker arm problem by changing the height of the rocker shaft by extending or shortening the stands that hold it off the head? It might require custom-length pushrods if you do that, however. What's the stock rocker ratio, and how much extra valve lift do you anticipate getting? On some of the small block Chevy V-8's I've built, changing the rocker ratio actually resulted in a horsepower loss on the dyno unless a massive amount of geometry correction was done, moving rocker stud position, etc. Jerry
