2 members (walter74, 1 invisible),
102
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | With the engine in the truck, be sure to support the frame, not the axle, on jack stands before trying to remove the oil pan. This lets the axle hang down low enough to get the pan off the engine. If weight is on the wheels, or the stands are under the axle, there's very little clearance and the pan might not drop down low enough to clear everything. Jerry
