I'm assuming you're talking about the small Chevy 5 on 4.75 pattern.
If so, most any early year GM car will work. What's your plan for the axles? Redrill or replace?
You may find that using 6-lug discs is the cheaper option.
CPP is one source, I'm sure there are others.
regards,
Leon
