| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 1/2 ton uses a full torque tube while a 3/4 ton uses a torque tube to the center bearing and open from there to the rear. A 1/2 ton in the 40's used a different U-joint at the rear of the transmission than a 3/4 ton. | | |
