Ok, I reread your post Alvin, and I do know what your talking about.
So are the Dodge perches the same size as my rear?
Someone said I could leave the torque tube hooked up, and that would be the correct angle for the pinion.
I wanted to drive the truck down to get it welded and then drive it back home to start on changeing the pumpkin, and trans out. Is it ok to do that or not? Thanks.
