| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Tim I have 2 ports on the bottom they are only about a 1/4 inch apart Close enough that the different gaskets expose a different hole I used the gasket that fit better The cab squeals (just a short high pitched burst) only if I hit the throttle quickly form idle. It is associated with a short hesitation. The engine also stumbles slightly at max rpm
Other than that it runs great and has good power to be honest I can live with the squeal but not the stumbling
Could all this be related to the same vacuum problem
As alway thanks for your advice it is always helpful
Rich | | |
