8 members (Greg_H, VEW, Joe H, Tinker5, Ridgeback, WICruiser, 2-Ton, Bill Hanlon),
140
2
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 33 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 33 | Thanks for the response. I took the truck to Las Vegas this weekend and the speedo would stop at 15 but only made a little noise every once and a while. On the way home on the other hand, I hit a bump and the speedo started screeching so loud that I had to pull off the freeway and disconnect it. From what I could see, it looked like the speedo cable was fully inserted into the speedo. I will pull the speedo out and inspect. | | |
