I have a technical question that I hope you can help me with:
I have a 1968 Chevy, Shortbox Stepside, with a 250 C.I. 6 Cylinder, 3-Speed. The VIN numbers support the 250/3 speed.
This vehicle was originally from Georgia and brought to Canada 10 years ago.
The issue is – the original 250 motor was replaced with a Canadian motor, verified by the serial numbers. I want to procure an original U.S. block for my re-build and have conflicting information on what the “stamped block serial numbers” should be.
I have an original 1968 Chevrolet Truck Chassis Service Manual and it states the following for engine identification.
Engine Number:
F - Manufacturing Plant (F-Flint, T- Tonawanda)
12 - Month of manufacture (December)
10 - Day of manufacture (tenth)
FA - Transmission and engine type
However, according to American Classic Truck Parts – “Truck VIN decoder” for the 1968 model, the numbers are one of the following: ( TA / TC or TD )
1/2-Ton TA 6 250 155 8.5:1 1-bbl Manual
1/2-Ton TC 6 250 155 8.5:1 1-bbl Manual
1/2-Ton TD 6 250 155 8.5:1 1-bbl Manual
If the “T” stands for “Tonawanda”, what does the following letterr following the “T” represent?
The Transmission coding from American Classic Truck Parts is as follows – the “W, K or S, do not correspond with the Service Manual?
W N/A 3,4 speed Warner Gear
K N/A 3 Speed McKinnon
S N/A 3 Speed Saginaw
Can you give me some feed back?
Please feel free to contact me off-line.
Larry Hull,
Ottawa, Canada.
[email protected]
None
