| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Don't know if this will help but here is a little tip that can take the guesswork away if you are considering installing a donor rear end. Take a stick and make it the exact inside measure. brake drum to brake drum of the original rear end. This makes for a very precise gauge while going to a junk yard to check sizes. Its quick and accurate. In my case I found a 1971 Olds rear end and the fit was within 3/4" of the original & it looks stock under my truck. Hope this can be of help to you. | | |
