| | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | The voltage drop across the reducer will change according to current flow. It's just a high-wattage wire-wound resistor in most cases. For instance, if a circuit that draws 10 amps gets reduced to 6 volts applied to a heater motor, etc., you would need a 0.6 ohm resistor with a 60-Watt minimum capacity. The resistor would consume 6 volts, and allow the other 6 volts to be applied to the heater motor. If the amperage changes, the resistance has to vary accordingly. Once the charging system kicks in and the available voltage goes up to 14.5 or so, all the calculations change. I like to use big wire-wound resistors with a sliding center tap so I can fine-tune the voltage for actual operating conditions, not some "one size fits all" voltage reducer. Jerry
