8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Disconnect regular power and jump direct from battery. See if that corrects.
Do not leave jumper hooked up for too long. I would not leave on for more than minute or two.
6 or 12 volt? Do you have a ballast resistor?
If corrects then coil distributor and all that should be OK and you have a problem in wiring between coil and all. First place I would suspect is worn ignition switch. Check all connections for tight and clean and good crimps.
If you have VOM do a wire by wire resistance check. All readings should be 1 ohm or less except coil.
Dan Bentler | | |
