| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,840 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,840 | I'm tinkering with an idea for a vacuum reservoir made of a piece of 3" PVC pipe with caps glued on the ends and a 1-way check valve like a brake booster uses to keep the vacuum from going away when the throttle is opened. Painted black, and tucked away under the cab inside a frame rail channel, it should be virtually invisible to the casual glance. Jerry
