7 members (GRNHydra, Forty9, Shardean, Ponchogl, SWEET, 78buckshot, Stovebolt48),
77
Mod | | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If your truck was damaged sometime in the past and not fixed correctly the door opening could be racked. It's difficult to explain but cross jacking with a port-o-power with one end pushing against the bottom jamb opposite the hinge and the other end pushing against the upper hinge area may get enough movement to address your problem. In the grand scheme of things 1/8" isn't a lot. It would take very little movement of the upper hinge to raise the back of the door 1/8". Understand that without looking this is just a guess of one possible explanation.
Entire Thread
Door Alignment, same project, new problem
| Jeff Misiaszek | 03/30/2011 1:16 AM |
Re: Door Alignment, same project, new problem
| Tiny | 03/30/2011 2:19 PM |
| BlueSteel3100 | 03/30/2011 2:23 PM |
| Jeff Misiaszek | 03/30/2011 7:31 PM |
| BIG CHEVY 3600 | 03/31/2011 4:01 AM | |
