Try these links:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290550097502&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370383723607&ssPageName=STRK:MEWAX:IT
If you're referring to the band-type brake that wraps around the drum at the back of the transmission, these pieces should to it. It's not terribly difficult to reline the band- - - -just be careful how deep you countersink the rivet holes. They should be countersunk about 2/3 of the thickness of the lining to prevent the rivet heads from scoring the drum, but still have enough thickness of material to get a good bond between the rivet and the lining material. I use a drill press with a depth stop and a step-ground drill bit to drill the holes for the rivets. It's very simple to set the rivets with a pin punch clamped into the jaws of a vise and a ball-peen hammer.
