I have the Old Air system in my 54 truck and it works fine even in 100 degree temps. The reason I went with O/A was that the hose hookups are made on the engine compartment side of the firewall instead of under the dash. The plus side is that hanging the evaporator is a cinch but the hose fittings are obvious on the firewall.
Operationally, the O/A unit cools the cab quickly on a high fan setting and then you drop down to the lowest fan speed which is just above a whisper. I've used the other brands and it was difficult to carry on a conversation: not so with the O/A unit. In addition, the O/A kit includes the correct bracket to mount the compressor low with either the alternator or P/S pump above.
I elected to fabricate a pass side engine mount for the alternator and run the compressor and alternator off a dual groove pulley from Buffalo Enterprises. My unit is controlled with a manual cable which I consider to be the best setup. I have pictures of the install in my Webshots Chevy albums. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
