Squeeze is correct. You have to have the fitting key,,then do the deal with the paper clip and twist it all the way to the right or left, depending on which type of lock.
I have a ring of abt. 150 keys and usually open them that way.
Good luck,,and be careful drilling it,,just a little too far and you can ruin the switch body.
