I'm sorry I said that wrong...when the choke is closed....it runs to fast...can't seem to get the idle to turn down.....so I have to open the choke to get it to slow down....
maybe this has something to do with it...I did buy a new (rebuilt)...the base to the new carb didn't work so I had to take the old one off and put it on the new carb....I changed out the old butterfly at the bottom with the new butterfly from the base that didn't work...Could that be why it is running so fast? Did I put the new butterfly somehow backwards on the old base? Because the idle screw doesn't really make a difference? Which way you turn it.
