Originally posted by tclederman:
Depends on your engine and depends on the canister.
If you have a 235 engine, then any by-pass oil filter should work OK with the engine.
If you have a 58-62 USA 261, then a by-pass oil filter will not work properly with it.
Why won't the oil filter work with the USA 261? Doesn't the engine have a place for the hoses?
