| | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72813 02/05/2007 6:41 PM | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | I think it is a 1946 3/4-ton or 1-ton 216. The "D" is for 1946. Check out this webpage http://chevy.tocmp.com/models/engine.htm#41eng . Keith has posted a LOT of useful info - for free, but some of it needs a little help. In the case of your ADCA serial no. The first "A" is a prefix for 3600 & 3800 series. The "D" is model year 1946. The "C" also designates 3600/3800 series and the last "A" is the plant code for Flint regular engine. The block casting number and casting date, both found on the passenger side of motor are also helpful. Good luck!
Professional Novice
