| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72811 02/05/2007 4:53 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Inliner site has casting numbers, you have the serial number. Someone here might be able to look it up in a book.
The casting number is usually in the vicinity of the starter. Raised numbers on the side of the block. You can usually find them by using a scraper on the block.
Fred 52 3600 69 C-10
