9 members (Southerntruck, MRMEROTH11, Oswald, moparguy, Hanks custodian, Jon G, Gray_Ghost, Peggy M, fonz8261),
107
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1959-62 will be pinched off from the factory to give full pressure to the shafts, before that there is an over flow tube. I would check your rockers to make sure they are 1959-62. The groove inside each rocker should be offset 1/4" from center. If the groove is centered let me know. If you can't find a connector PM me, I can help.
See the USA in your vintage Chevrolet! My Blog | | |
