1 members (Otto Skorzeny),
40
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | My Posting "Igniton Switch" will explain the problem I am having with the ignition switch. After my last posting I did some more trouble shooting and here is what I discovered. I removed the switch and connected a hot wire directly from the battery to the bat terminal on the switch. I connected a test light to the sol terminal and the ign terminal and when I turned the key to the start position the test light came on. This I felt proved the ignition switch was good. So I ran a wire directly from the battery to the switch and tried to start the engine and nothing happened. With the switch installed and all the wires connected I used a test light to see if power was getting to the sol and ign terminals, which it was. I reconnected the orginal battery wire to the switch and the engine would crank and fire but not run. My question is 1. why didn't the engine crank and fire with a direct wire from the battery and 2. is the soliniod wire supposed to be hot all the time? Electrical is a weak point with me so any help would be appricated. Thanks Redo | | |
