| | | Forums66 Topics128,102 Posts1,056,533 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 37 New Guy | | New Guy Joined: Oct 2009 Posts: 37 | Barsteel
Appreciate the humble attitude. I too have been teaching myself autobody paint.. for about the last 4 years and it takes a lot of practice to get street rod hand rubbed results. (my work now looks better than 2010 factory base coat/clear.
I assume you are doing just a single stage? Basically the results are locked in with sanding. Block sanding is must, but after dry sanding I switch to block wet/dry sand at 600, apply filler prime, block wet sand 1000 and then final prime and knock it down with a light 1200 prior to final paint. Over filled areas multiple top coats is a must. If it is single stage I will then rub out the final paint with 2000-2500 and use a buffer with a 3M perfecta compound to bring it back. I still do the same on a clear coat, but many are satisfied with the factory finish.
good luck, it takes lots of practice
Entire Thread
Disappointing results, what to do...
| Barsteel | 02/28/2011 12:47 AM |
Re: Disappointing results, what to do...
| Lightholder's Dad | 02/28/2011 1:09 AM |
| squeeze | 02/28/2011 1:37 AM |
| Olblue3600 | 02/28/2011 2:02 AM |
| Barsteel | 02/28/2011 2:56 AM |
| JeffL | 02/28/2011 3:27 AM |
| Bill_B | 02/28/2011 6:21 AM |
| jomichael | 02/28/2011 8:57 PM |
| Olblue3600 | 03/02/2011 5:35 AM |
| JeffL | 02/28/2011 1:56 AM | |
