0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The resistor that drops the voltage to the heater will act like a dead short on the way to the gas gauge. You'll need a totally different resistor to handle the tiny current draw of the gauge, with a lot more resistance that the one used for the heater motor. If you don't have a pretty extensive knowledge of electronics, you're going to be spinning your wheels trying to make the gas gauge work. I'd suggest a voltage divider circuit using a potentiometer that applies just enough voltage to make the gauge read full with the float at the top of its travel, and empty as it reaches the bottom. Jerry
