9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53),
236
0
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | You can use this set-up with front drums. You would run a 10 lb. residual valve in place of a 2 lb. residual valve.
I like this design from the standpoint of it mounts in the existing holes in the frame and you don't see it once it's done. I'm assuming your reference to the American model is the one that mounts to the firewall and has a pedal that swings down?
That method would work better, but doesn't look as original! | | |
