| | | Forums66 Topics128,078 Posts1,056,055 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If you're keeping the SM-420 4 speed, you won't need a crossmember under the back of the transmission. For the under-the-bellhousing crossmember, put an ad in the "parts wanted" forum and see if you can find somebody who has converted a V-8 truck body to a later model frame. They might be willing to make a deal on the crossmember you need. The 48 crossmember won't accept the V-8 bellhousing mounts. Up front, you'll need an aftermarket tubular crossmember to adapt to the side mounts on the V-8. Jerry
