0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It sounds like a carb problem but you said you tried another carb. Have you set the idle speed up like Cletis says. Try turning the idle jet richer. Put your hand or a rag over part of the carb neck & see if the speed picks up. If so you hbave a vacuum leak or plugged idle passages. What part of Ks. are you in? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | |
Entire Thread
Help! 216 Will not run at idle, only at higher rpm
| edub10068 | 01/24/2011 4:10 PM |
Re: Help! 216 Will not run at idle, only at higher rpm
| Highflyer | 01/24/2011 5:08 PM |
| edub10068 | 01/24/2011 5:39 PM |
| bigbadswingdaddy | 01/24/2011 7:21 PM |
| tclederman | 01/24/2011 8:20 PM |
| edub10068 | 01/24/2011 8:59 PM |
| Justhorsenround | 01/24/2011 9:22 PM |
| joker | 01/24/2011 9:25 PM |
| edub10068 | 01/24/2011 10:46 PM |
| Wrenchbender Ret. | 01/25/2011 12:27 AM |
| joker | 01/25/2011 1:48 AM |
| Wrenchbender Ret. | 01/25/2011 9:37 PM |
| edub10068 | 01/26/2011 10:48 PM |
| edub10068 | 01/25/2011 12:38 PM |
| yar | 01/27/2011 1:31 AM | |
