3 members (Danielbolt, bluechev, 1 invisible),
104
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 194 Shop Shark | | Shop Shark Joined: May 2008 Posts: 194 | OH crap! I will have to look at mine. But for me it is too late. Got it months ago from Classic Parts and I decided to paint it before testing the fit. Visually it looked OK other than my old tank looked a bit straighter, as far as the actual full lenght of the tank was concerned. And there was a bit of shipping damage.
Mine is for a 57 3100 but looks like a have problems. The tank kind of fits the floor OK but the filler necks are off quite a bit! They are pointing too far up and to far into the cab (forward) area.
And I see that the little bump from shipping that bent the edge of the pipe actually pushed the pipe base mounting area in at the top of the gas tank and out at the bottom of the filler neck So mine had more damage in shipping than I thought! crap. Should have regected it from UPS.
And to top that off if I cover the sender holes and the filler neck and pressurize the tank a bit there is a leak somewhere around the base of the filler tubes or in the seam of the tank around that area. I can not tell exactly but it leaks air so it will leak gas. That is why I was replacing the original one!
Well I guess I ate that $145 plus $28 shipping.!
I guess I could look into having someone try to bend it back into shape and try to weld the hole wherever that is.
Is that stupid or is it something that could be done?
EDIT: I found that there is a really small pinhole at the base of the big neck where it attaches to the tank. Is there a way to patch it? Like with JB-weld or something? I see they have a JB Water Weld that they say can be used for gas tanks, water and fuel cans, ruptured radiators, oil pans etc.
Also is three a good way to bend the pipes back into alighnment? They need to go down and toward the back of the cab about and inch or more in both directions.
Also how in the heck do you get the outside gas tank filler neck grommet on and be able to still put the filler neck up throught it?
I tried putting the grommet on and then put the filler up thru it from behind but there does not seem to be a way to do that. Hole is smaller than the filler neck. Also tried putting filler neck way up as far out of the hole as it would go and then put the grommet on but there is no room to manouver and get the grommet into the hole and fit around the inside of the hole. What is the correct way to do it?
Entire Thread
So, just how did you install that Gas Tank?????
| Denny Graham | 11/22/2009 10:31 PM |
Re: So, just how did you install that Gas Tank?????
| Pete52 | 11/23/2009 12:05 AM |
| pablos49 | 11/23/2009 12:09 AM |
| Denny Graham | 11/23/2009 2:14 AM |
| AD_Pickup | 11/23/2009 3:07 AM |
| Denny Graham | 11/23/2009 3:12 PM |
Anonymous
| 11/23/2009 6:03 PM |
| Denny Graham | 11/24/2009 4:36 AM |
Anonymous
| 11/24/2009 3:21 PM |
| MarvelMysteryEar | 11/24/2009 7:24 PM |
| ia49 | 11/25/2009 4:45 AM |
| chrmc | 11/25/2009 6:14 AM |
| Tripleeeng | 11/27/2009 4:25 PM |
| Denny Graham | 12/02/2009 4:04 AM |
| Silverado_9c3 | 01/05/2011 5:01 AM |
| Denny Graham | 01/05/2011 5:20 AM |
| webstershotrods | 01/06/2011 5:51 AM |
| svwilbur | 01/15/2011 2:17 AM |
| hankrags | 01/15/2011 8:04 AM |
| svwilbur | 01/18/2011 1:19 AM |
| svwilbur | 01/19/2011 10:39 PM |
| neilroy | 01/20/2011 3:38 AM |
| oldbluetruck | 01/24/2011 7:52 PM | |
