in the dallas craigslist is a 3 speed OD that will bolt into your truck, make sure you get the wiring harness, relay, and od lock out cable. Make sure that the OD unit stays full of oil, if not it will lock up or break. It always keeps the ool to the main gear case. if not, go with a 200r4 which has vacuum shift.
If you go with a sag 4, change your rear end to use 4th as an OD
