Hy harborarea, your post is difficult to follow, are you saying that you have installed a much newer engine and transmission in your truck? And you can't make the shift linkage from the old transmission work with the new transmission? The shifter arms on the new transmission are probably totally different in shape and design from the old transmission, you may have to make extensive modifications to the linkage to make it work. The clutch linkage may also need modification in order for it to make the clutch work properly.
