I would start with 4 and only go up if you have overheating problems. A pressure system allows more heat transfer because it allows the water to be hotter before it boils over. If it doesn't boil over at 4 then leave it alone, it will be easier on the seals. 7 may be safe but I wouldn't go there unless you need to.
Paint & Body Shop moderator
