I got the Newport's as well through Bowtie Bits. No real world service yet but install worked as described, a quick test shows everything in working order. I added an aftermarket switch with delay and washer pump feature, looks just like the one it came with, plan to put a generic period correct knob on it for further "originality".
If you return their drill jigs you get a t-shirt - better than a poke in the eye.
I'd also suggest mounting using rubber washers to minimize operating noise.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
