It sounds like a carb. problem. With the engine off look down the throat of the carb & move the accelerator. You should see a squirt of gas going in the throat. If not the accel pump may be bad. The float level might be low. Try advancing the spark a few degrees & see if it improves.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
