1 members (1 invisible),
70
6
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The trans will hold p just fine. Open versions of the same transmissions were used behind some of Chevrolets most potent engines all the way up to the mid '60s, including Power Pak and Feullie 283s and 327s, plus they were even found behind 396s and 427s as the base transmission. BTW, I've ran mine, which is the open version, into the triple digits without any problems at all, so 65 shouldn't be a problem.
Bill Burmeister | | | |
Entire Thread
need info; newer rear, newer trans, open drive!
| Smith | 09/24/2010 5:19 AM |
Re: need info; newer rear, newer trans, open drive!
| squeeze | 09/24/2010 5:44 AM |
| Smith | 10/06/2010 2:09 AM |
| Cletis | 10/06/2010 2:54 AM |
| Smith | 10/06/2010 11:48 PM |
| Cletis | 10/07/2010 12:47 AM |
| Smith | 10/07/2010 2:45 AM |
| DrewP | 10/07/2010 3:20 AM |
| yar | 10/13/2010 4:40 AM |
| yar | 10/13/2010 4:43 AM |
| DGERTH | 10/20/2010 3:47 PM |
| Smith | 12/13/2010 1:43 AM |
| tclederman | 12/13/2010 2:05 AM |
| Smith | 12/13/2010 2:14 AM |
| LONGBOX55 | 12/14/2010 10:02 PM |
| Highflyer | 12/16/2010 6:04 AM | |
