| | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No such thing as a bolt in... unless you get a 55-59 chevy or gmc rear. Interesting side note... gmc rears had a 3.08 ratio available.
The closest to a bolt in would probably be a 10 or 12 bolt truck rearend. If using a 1960s vintage 12 bolt, even your parking brake cables will work. The perches do have to be cut off and new axle perches welded in. | | |
