| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Not without your rearend ratio. I assume you will be changing rears to an open drive rear to make this work. Transmissions of choice may be determined by therear gears you end up using.
An A833 would be high on my list if the rear gears were between 3.73 and 4.11.
A Muncie m21, m22, or a saginaw 4 speed or even a warner T10 would be on the list if the gears were 2.73- 3.23.
This has been discussed at length many times before. Do a search on the subject of rear gears and you will find more information than you could ever want. | | |
