| | | Forums66 Topics128,117 Posts1,056,298 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | It could be the turn signal switch, or it could be a bad wire to the firewall connector. The manual says it light blue (LBL) you should have two LBL wires at the inside of the firewall connector. One is the turn signal switch, and the other is the right hand signal light. If the wire is good, I have seen the contact pin in the switch overheat and loose contact.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
