2 members (jay d, Gdads51),
75
2
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69881 12/11/2006 10:49 PM | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | To the best of my knowledge, I don't think you are going to find the correct 4 Bl intake for a 66 283 in a truck as they did not offer a 4 bl until about 69 and that was a 350. Probably the ones you have seen on other trucks are either aftermarket or from a passenger car. There is one metal line with a vacuum hose attached that goes from the carb to the distributor vacuum advance. There could be a line to the choke also. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
