Somehow we lost Denny's reply when I moved this post. Maybe he will catch that.
Anyways, I find that when I use my heater, I use it on full. It isn't all that affective so I don't need the resistor operation. If you cut the resistor then you will have it either off or on and that should work fine. Mine lights up when it is on and that is a nice feature.
1951 1 Ton Completed
