| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69731 12/07/2006 11:44 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | It comes out as a unit, sorry. While you have it out it would really be best to do a complete rebuild. If my memory is accurate, the only special tools needed is a method to measure the end play or clearance in the drive train from the front of the main case to the thrust face of a shaft. This requires a selective fit washer to get it right.
You really want to measure this once and set it up right. I distinctly recall R&Ring a 60 cast iron PG 8 times because I tried to use a jury rigged tool to do this measurement. | | |
