3 members (Wayne67vert, crenwelge, 1 invisible),
475
6
Mod | | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Dave, I did the switch (upgrade) last year, here are the pictures. http://rides.webshots.com/album/571837084bSxNPfDo not buy the REZ kit, it is really made for the 63-66 frame. It will not bolt up the best way. IF you have the 60-62 you will need to get the Classic Performance Products (CPP) kit, you also get the steering shaft adaptor, which you will need to shorten the shaft. Jake
